Buffaloman
I recently purchased a Ford 860 serial # 16516 (1955). The air cleaner tube from the cleaner to the carb was missing ( among other things) so I purchased the part and attempted to install it. What I found was the solenoid switch was bolted to the starter. (The switch works, etc.) Because of the switch, the air filter tube to the carb wont fit. I then saw two threaded studs on the battery box and also noticed the studs seem to fit the solenoid mounting bolt pattern. I think if I move the solenoid to the battery box, the air cleaner tube will then be able to go to the carb. Is that how it should be???
Does anyone have a photo of the proper location?
PS the tractor has been converted to 12 volt alternator. Is the replacement solenoid part the same for a 12 volt as as 6 volt?
