5610S injector pump
doorman
Working on a 5610S with a bad pump. Is there a pump on a different model that will fit and work on this tractor? Thanks for any help. doorman
Pumps are getting pretty specific with emissioned engines by that point in time... There's probably a couple that could be used but would be fueled incorrectly. What is wrong with this pump?
Rod
Very good chance I have the parts here to repair your pump, Should have a CAV DPA pump. I have seen some late fords with the DPS. Feel free to give me a call. I am sure I could repair what you have and not cost and arm and leg. Good luck,,, Al 231/757/0064
No, that engine will most likely have a DP203 depending on what year it is. Before 97 will have a DPS.
Rod
