I have recently put my tractor back together after replacing two gears in the transmission. Upon putting it back together, I have two problems.
#1) I have notices that when I push down the left side brake pedal and release it, the pedal will not come back to the top position. The brake pedal on the right side
will come up, but not all the way. I suspect a spring or something is worn and needs replacing. Is this the case? If not, what?
#2) I have had an ongoing issue with my clutch. The clutch bearing doesn't touch the clutch fingers until the pedal is almost to the floor. I have the clutch pad on
right. I have replaced the fork, pin holding the fork, springs and clutch bearing. The adjustment bolt cannot be adjusted any further. Is there something else I can do or
check to solve this problem?
