Ford 3000 Lift Problems
Runner MAN
New User
The lift on the 3000 goes uo just fine except it slowly falls down after a few minutes even with the tractor running, I checked the Hydro Fluid and added about two quarts. I poured the fluid in the top of the diff housing removing the small plug in the side of the transmation to check the level. Thanks
The 3000 will have a level check plug for the transmission and one for the rear end. You need to pull the correct check plug for the rear end as it is different from the transmission level. As to dropping, suspect bad unload valve or bad lift piston seal?
