ford tw10 or two master cylinder o/h kit
jim_uny
i think i previously saw post that ford 9600 clutch master cylinder rebuild kit was avail thru napa. is there also one for tw10 and tw20. can you provide napa part nbr or other equivalent. also what is technique to search only ford forums. txs
Jim...can't help with Part number but to search you need to be in modern view, click the search button in the blue box underneath the gray bar in upper right portion of page. When the search page opens you can type in your key words and then in the options section select which forum you want to search...Dan
The NAPA part number (M34404) was for a complete master cylinder but was not compatible with the mineral oil type brake fluid. It helped me because my MC was beyond repair. I still had to put the correct kit in it. I got mine from CNH dealer. I saw one listed on !bay that is supposed to be correct for maybe $80. Not sure if mineral oil compatible
