2600 adding rear remotes, has power beyond for loader
Eman85
I have a 2600 diesel which has a Bush Hog loader. The tractor has an aluminum 2 port power beyond block which feeds the loader. Can I add another block and feed a remote connection at the rear of the tractor? If I did this do I have to close off or disconnect the loader for the rear ports to have pressure?
on top of that block is a blank cover. if you had a ford OE style valve you could simply stack it and use the oe under seat valve for a rear remote.
I'm pretty sure that you can't run with two power beyond plates, but I haven't studied it that closely to be able to say for sure, because i never thought about it before.
Does your loader control valve have power beyond capability? If so you could use the power beyond port from the loader valve to power a regular open center remote valve.
Or, as souNdguy says, add a Ford specific remote valve in place of the plate that is on top of your power beyond plate.
Yes, you can stack them as long as you return the fluid and use open center controls. but why, when you could get the same thing by simply using the return from the loader control to feed the new control and then return it to the exiting power beyond block.
(Or as others said, get the ford remote to set on top of the existing power beyond block.) The pbb simply intercepts the hydraulic flow and then returns it to be used.. first to the remote if equipped, and then sent back down to the 3pt lift, in that order. Once you have it out of the tractor, take it everywhere you need it, but be sure to return it for the other functions and use open center controls... open center controls means when your not using the flow, it returns the pressurized flow down stream to the next device to use.
The 3 pt lift always is last as its design throws away any unused flow to the sump and it cannot be used past the unload valve.
My loader is a removeable one, when i remove it I hook the 2 lines together. Just wanting to clean it up and not have lines hanging if I don't need to.
http://www.ebay.com/itm/181626157767?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Will this work stacked on on top on my PB block.
http://www.ebay.com/itm/Ford-tractor-Jublee-600-800-900-2000-3000-4000-hydraulic-remote-valve-/272014823459?hash=item3f5558d023:m:mP_Ifwh-hlNQ_5BFY01J6eA
This is a double two way meaning you get four ports off of it... buy yes, that one will work as well in lui of the top plate.
