Follow up to Ford 4000, gas, 3-cylinder rough running
rams2050
New User
I replaced spark plugs, spark plug wires, rotor and distributor cap. Nothing helped.
Tractor repair picked it up and took it in to shop and told me a push rod had become unattached.
What could cause something like this to happen?
Anything I can do to prevent same from happening in the future?
Thanks.
Bob
kicked a push rod?
usual cause would be a stuck open valve.
this can also lead to BENT push rods.
Hope they checked it for true / replaced it if it was bent. even a SLIGHT bend will make them more likely to kick off or re-bend.
Intake valve? Varnish (from consuming old gas) builds up a lacquer on the stem.
The hot stem cooks off the lighter molecules and leaves the longer chained stuff
behind to glue up the stem.
