Patrick Potter
I've make a couple of post about this problem and here's where things stand now, I've replaced the seals for the lift piston and all the other O rings, and I've rebuilt the pump and here's whats happening, pressure test only shows 500PSI it did go to 1000 & 1500 a couple of times but dropped back to 500, when I lift the 3 point to a certain height it will drop slowly to a point and then jerk up I can lift it nearly all the way (what I call transport height) it'll hold, also I can put the draft control; lever (on the right hand side of the seat directly under the seat) in the down position and when I raise the lever and I get the lift lever about 3/4's the way up it feels like something inside breaks and the 3 point drops rapidly and then there is no resistance at all to the lift lever now after I put the draft control lever back in the up position the lift lever starts working, put the draft control lever back down and the lift lever will work until I go pass about 3/4's point it again feels like something breaks and there is no resistance again until I put the draft lever back in the up position
