where to get hydraulic remote parts
deadbuck
Can anyone tell where I can get a couple of these? They screw onto remote might be called banjo bolt not sure
Ford used the banjo and the hydraulics industry says it never existed.
However an 90degree male orb to female npt fitting will be the same. Its orb at the tractor, and usually npt, jic or orb on the other end depending on what your connecting to.
Eaton Weatherhead (P/N 06U-L06) still makes a crimp fitting for a 3/8" hydraulic hose. The banjo bolt portion and seals can be bought from CNH. Keep in mind this will cost more than an orb fitting and adapters. I bought all the parts and had the hose made but haven't had a chance to install them yet but will be the end of this month. I'll try to remember to post my results and some pictures.
Banjo crimp fitting
