Starter switch on a Ford Jubilee tractor
BC4gwkto
New User
I have a Ford Jubilee tractor that has a ON OFF Start switch on it. I would like to go back to the original switch that came on the tractor ,the push button on the transmission, but I don't know how to wire it for the push button switch . Can you help?
(quoted from post at 14:14:46 10/09/15) I have a Ford Jubilee tractor that has a ON OFF Start switch on it. I would like to go back to the original switch that came on the tractor ,the push button on the transmission, but I don't know how to wire it for the push button switch . Can you help?
First step is to install the correct solenoid. Sounds like you have a solenoid requiring power to small terminal to activate it. You need a solenoid that requires ground to small terminal to activate it.
