Anyone ever replaced the trans seal sleeves on the output shaft and counter shaft? Refer to I&T Manual FO-20, Figure FO148, parts # 17 and # 34.
Mine are SO deeply grooved and worn, new oil seals will be ruined in short order. Can I just "pull" these sleeves off the shafts from the back by some easy method? Or am I looking at tearing the trans apart and then using a hydraulic press to get the old sleeves off/new ones on? (I have the new sleeves) I've not found any advice on this on a forum. Anyone ever tackled this?
