I installed all new gauges and a sending unit (purchased the kit for those era Fords) on my Ford 641. The tractor has all new wiring and new everything. It was installed a couple years ago and just finished the tractor this week. Put a couple gallons of fuel in it and the gauge moved up a little as expected. Well since I finished re-doing the tractor, I figured I'd dump 5 gallons in it to make sure it had plenty of fuel and to check the operation of the gauge. For some reason the gauge only read about 1/4 of a tank....actually a shade less. I also noticed that the gauge doesn't sit still. Sometime it will "jump" between setting (not float but jump). Have I done something wrong or should I remove the sending unit to check?
