Ford 860 Headlights
My_User_Name
New User
Does anyone have a diagram (or picture) showing how power feeds are routed to the headlights? The wires for the R & L lamps exit the harness near the generator wires; the entire harness is well secured along the whole machine, but these two headlamp wires don't seem to have a safe place to go (considering that they're near the fan belt, hot exhaust pipe, etc.). Thanks...
on my 640 I just disassembled, which appears to be all original, the headlight wire comes up from the generator, runs along the upper radiator hose up to the hood. it then runs across the front gas tank support I believe to either light
(quoted from post at 09:15:14 10/05/15) on my 640 I just disassembled, which appears to be all original, the headlight wire comes up from the generator, runs along the upper radiator hose up to the hood. it then runs across the front gas tank support I believe to either light
That is correct, there is a special retainer that clips over the upper hose.
