what can you tell me about a 532 square baler? I found one that has been sitting for a long time that i can get quite reasonable.
the needles aren't not broken and it has no kicker on it. I am only looking to make about a 1000 bales at most a year. how are
parts to come by?
Parts are getting rather difficult through CNH and what is available is expensive. That's not to say that you can't work around most things... but it would definitely help to have a parts baler and be handy with making stuff yourself...
The biggest thing you are likely to run into at some point is a bad over running clutch that is built into the PTO shaft/hub where it meets the slip clutch... They fail. They cost over 400 bucks the last I looked.
Other than that it's not a bad old baler if you set it up right and keep it in tune. I wouldn't pay more than a few hundred for a decent runner known to tie.
Rod
