The weather went unseasonably cool today and it got me to think about plans for indoor projects. What do you guys have planned for your tractors when the weather pushes you indoors this year?
I'm pretty much on top of the immediate needs of my 640. I have two specific goals in mind for the Winter.
1) I want to take the slop out of the steering from front to back. That means installing the spindle bushing kit and rebuilding or replacing the steering box. All of the tie rod boots could use replacing too. Then I fear mission creep might expand the project. lol.
2) The other project is to fit up 18.4 x 16.1 tires on blank rims. I'll mock up a blank rim with a tire mounted to set the backspace for the wheel centers. Dismount the tire. Then true up the center to the rim at the correct measurement and weld them in. Bead blast the welded assembly, epoxy primer, paint, remount the tires and wait for Spring!
