cbrown9064
So the old girl (861) had no fire. Was running, then not. Found one button on the points fell off, new points, condenser and rotor. Nice strong spark.
Started up, ran and died. No restart. Pulled the plug on the bottom of the car, very little. Ahhh, says me...fuel issue. Sediment bowl dark, took it off, cleaned and put back on. Leaking. Try to start tractor, no go. Give a little carb spray, backfire, fire. !!!!!!!
Get fire out. Sediment bowl broke in the process.
Out in rural, northern MN. Anyone know of a place to get a replacement bowl and gasket? Or even a whole new assembly that fits?
Short of ordering that parts (this old gal is 300 miles from home) any way to get her running again? With that special bolt into the carb, don't know how I would get a fitting to work with those threads/gasket.
Thoughts?
Thoughts?
