Update on the Jerry rigging.
Ultradog MN
Location
Twin Cities
So I'm still up north. Doing some painting in one of my rentals before the 1st.
I worked till 5 yesterday then Hooked the bush hog up.
The SOS PTO kept disengaging so I had to hold the handle out. Is there an adjustment for that? I also have to hold the throttle handle as it slips back down to idle so no hands left for steering. Simple to adjust the throttle but like everything else a pia on a platform tractor.
But then the 3 point quit lifting. I had changed the pump b4 with new CNH orings and it was working fine. Just quit.
Discouraging.
I'm just going to park it and go back to my little sweetheart 3000.
Well the PTO and throttle that is a easy fix just grab some baling twine or wire and tie them where you want them LOL
Sorry to hear you're having trouble with it.
Does that have a draft/position control lever like the earlier ones?
I somehow bumped it on one of my tractors and the lift wouldn't
work until I moved it back into position. I cycled it actually.
I'm sure you know about that lever on the priors, just thought
I'd mention it. Worth a shot if so equipped.
