Clutch/gear
Deereman1
When I press down on clutch and put Jubilee in gear, I get a noise(not grinding). I have to let out on the clutch for it to stop. The tractor has a fairly new clutch in it. Can someone please tell me what it is and I can solve this issue? All help is greatly appreciated.
Thanks
When you changed the clutch disc did you remove the throw out bearing from the carrier, degrease it and add new grease? Was the throw out bearing replaced when you serviced the clutch?
If these steps were not followed, to me it sounds like a noisy throw out bearing.
Ok so lets dissect what you have said so we are on the same page. The noise is only there when you push the clutch pedal down and shift in to gear??? Or is it there the moment you push the clutch pedal down or what?? If it is there the moment you push the pedal down then as asked did you replace the throw out bearing or leave the old one in?? If it happens once you put it in gear then did you replace the pilot bushing/bearing?? If you did not then good chance that it where the problem is
I'm not sure if the throw out bearing was changed or not. The Man I bought it from just said it has a new clutch. Just to narrow it down, it makes the noise when press the clutch and put it in gear, not when I press the clutch alone. It doesn't do it in reverse..Also, it never did it when I bought it earlier this summer. It just started doing it recently.
ok, so no noise just pressing the clutch, but when putting it in a gear, yes.
only when shifting, or once shifted in gear, but still clutched, still makes noise?
any gear or just 1 gear?
