Judson Marvin
Hey guys. The 3pt hitch on my 600 doesn't work properly. When I first start the tractor up and slide the selector lever into the lift position. Most of the time the arms will go all the way up. Sometimes they will go half way up and you have to move the selector lever ahead slightly and then back to lift position and the arms will go up slightly. Have to repeat this step 3-4 times to get arms all the way up. If I move the selector lever forward at all the arms will go down as if it's in draft control. If I push the draft lever down so that' it is in draft control nothing happens when I move the selector lever. I have removed the full port and looked inside as the piston goes in and out and I don't observe any fluid spraying as if a seal went bad. Any pointers would be greatly appreciated
