Order Ford 841 Parts Online
Re: 841 Battery Discharge update 12V
soundguy
09-22-2015 10:33:30
the ignition switch actually prevents the alt from draining thru the excite line when off, since when key is off, the idiot lamp is not hooked to power anymore.
the lamp is there to drop voltage and reduce current on the excite line, since it is also common to the coil...otherwise the excite line would backfeed the coil preventing you from turning the tractor off with the key.
