Order Ford 841 Parts Online
Re: 841 Battery Discharge update 12V
old
09-22-2015 08:19:29
Do it the easy way and hook the #1 or R to the ignition side of the coil. That way you know it is on the ignition side of the switch. But of course you need a diode or resister or light bulb in that wire or you will not be able to shut the engine off due to alternator feed back. I wire lots of tractor up that way to save on wire and make it a simple hook up
