This past weekend I installed a new water pump, hoses, and thermostat. Found out when I took the tractor back for running hot they obviously pulled the thermostat out as I installed the 160* thermostat and found out that just using the shreader running the engine at 1200 rpm resulted in 210 to 225* temps.
As of now I ordered a radiator from "external_link" as it was the only one I found that did not require modification to the original fan shrould due to their relocation of the drain petcock.
I will see what quality it is when it comes in but I know this engine shouldn't be running this hot and I believe the culprit has to be the original radiator is stopped up and is not cooling.
I could understand 180* temps holding steady with 90* ambient air temp but anything over 200* is just screaming something isn't right. Might have to look at timing as well after this as well.
Now to get to it, what has to be removed to get to the radiator? All of the sheet metal or can I remove just bits and pieces.
