John Deere 450 B fuel injector broken???
ZANE
I'm trying to buy a 450 B John Deere crawler loader. It has been sitting for about two years. I was trying to crack the injector lines at the
injectors and apparently have broken something down the line from the injector line nut??? It just turns below the line nut. What did I do and how do
I fix it????
Neither of the steering clutches will disengage. Is there any trick to freeing and or adjusting them?
Thanks for any help you can give me.
Zane
Never mind. I found what was wrong once I got all the crud from 40 years cleaned away and it just needed the nut on the injector line held while the injector line was tightened.
Now the steering clutches.
Zane
