Hi Folks,
I a have a 1971 Ford 4500 3 cyl. diesel tractor and I am in the process of replacing the engine with one from a 1973 4500. When I pulled the original engine I noticed a 1/4" layer of dirt and grease along with about an 1/8" of hydro fluid and some water in the bottom of the bell housing.
The weep hole was completely blocked so I don't know for how many years this has been building up. My question is; is this typical or should I be concerned? Should I replace the seal on the transmission case or output shaft of the transmission and if so how difficult is it? It is a 6/4 Type K transmission with only 1 output shaft for the clutch disc.
I will replace the clutch disc (13"; 10 spline), but should I also consider replacing the pressure plate assembly? It seems to be fine, but I think it might be the original as it is a Borg & Beck from England. What about the release bearing and hub (greaser) as it seems to be in good shape. It looks like it can only be replaced as one whole unit and I only see New Holland selling it at a price of $662 at Messicks.
Along the same lines since I have the engine out I would like to replace the front and rear main seals on the engine. I have never done this before on any engine so I don't know how difficult it will be after the flywheel and front crankshaft pulley are off. How difficult will it be and is it a good idea to do?
Thanks,
Ray
Thanks,
Ray
