This is a followup to the 71 2000 Ford 3cyl with disappearing PS fluid. I tore the pump down and installed a YT seal kit. This is the motor mounted pump with integral reservoir. The front seal was definitely loose. I replaced all o rings and reassembled. Did not open the relief valve. It was making good pressure before.
Now it will not make pressure. I removed it and disassembled/reassembled again following the exploded view in the IT FO-31 manual (all I have). Reinstalled and still no pressure.
What can I check next? Can the bearing blocks be installed backwards? There is an item 15, called ring dowel. Did not find one. Is it there in all pump models?
John
John
