kingslandkid
Hi all,
This may come as kind of a stupid or redundant question but I can't seem to get a satisfactory answer. First a little background on my Ford collection. I have the following: 3550 gas, 340 gas, 340 diesel, 65 3000 diesel, (2) 3600 diesels, 3910 diesel and older Fords. I have completely rebuilt the 3000 and both 340's engines and had all of them sleeved back to standard. The only reason I did the 3000 was it sounded like it had a loose wrist pin. After the rebuild I was expecting a quieter engine, but it was the same. I have five other diesels, (2) 4000 four cylinder's and (2) Japaneese diesels and 1 Kubota. The 3 cylinder Fords are by far noiser than the latter mentioned models. The two gas three cylinder engines or super quiet.
I know diesels are noisy when they idle but these sound like something is loose. I have been told that it is the backlash in the gears in the valve/pump train but the last diesel I rebuilt had all new gears and it is the noisiest. I have ruled out combustion since it makes the clanking noise as the engine is coasting down to a stop with the fuel shutoff pulled out.
I love these Ford 3 cylinder diesels and use them to mow and do landscaping with and have learned to live with the noise but I would like to know why they are so noisy? I'm sure there are Ford enthusiasts out there that can tell me once and for all what make these engines so noisy.
P.S. A fellow just brought me me over an old 5000 diesel to work on and it too sounds like the wrist pins are ready to let loose.
