Ford 3000 Wheel Weights
jf
I removed the calcium from the rear tires and replaced the rotted rims and want to know what rear wheel weights were made for that tractor. It's a 1966 with the old style external drum brakes on the end of the axil. I have some old Fordson wheel weights I can hang on the 3 point, but would rather have something more factory. Thanks for your help.
This style should work on your tractor or Pie weights if you can find them at a reasonable price.
Kirk
There are many styles of weights that will fit your tractor.
Pretty much any type that fits a 28" wheel will work.
So any weight for an N Series all the way through the 3600 will work fine.
Lets you expand your search if you know that.
Around here the going rate is around $.50/lb for any type.
Some of the N weights might not fit if mounting them on the inside cause the drum is bigger. Pays to bring a ruler before making a purchase.
Kirk
There's a mounting plates and special lug adapters for the pie weights. Best to buy as a complete set.
Kirk
