Hey guys. I got my 641 back together after a new clutch install and started her up after 4 years and she is running just like she used to. .....really good. Only problem is that the Hyd. Lift isn't working at all. I put new fluid in to the bottom fill line on the dipstick (back 3 pt. arms are down and have been) since the other fluid drained out during the split. Started her up with the filler plug off to let trapped air out. I get no response when moving the up/down lever. Is there a way to bleed air or prime the Hyd pump on the motor or do yall think it is something else.?? I know with the farmalls, you just let it run while you cycle up and down with filler plug off til the trapped air escapes. Please help. I hope I don't have bigger issues
