Judson Marvin
Hey guys I have a ford 600. The 3 pt hitch won't stay up unless the lever is all the way back in the up position. As soon as you move the lever forward any the arms start to go back down. When there's an implement attached it is real jerky picking it up. But won't pick up all the way. You have to slide the lever a head an inch and then pull all the way back to the up position several times to get it to go up all the way. I did take the fill port cap off and look inside while I operated the lever back and forth. I did not observe fluid spraying to indicate a bad deal which I originally thought. Thanks for any input
