I've got a Ford 861. It's typically been a bit "smoky" which I've posted questions on before. It sees limited farm use, but has always run pretty reliably. Yesterday I went to disc up a field and in the middle of running it, it died, almost as if it had run out of gas. (Tank was 1/2 full with new gas). I also noticed before it died that I was having to give it more throttle than typical to keep it running. After leaving it for a bit, I started it back up (started on first push...), and it ran for a couple minutes and then died again. It continued this as I drove it back to the barn...
Any thoughts on where to start looking for a problem? Thanks.
