841operator
New User
I have a 1954 naa ford tractor that I have been working on for probably 2 weeks now. I have rebuilt the pump, I have rebuilt the cylinder, and I've installed all new gaskets on the lift cover. I took off the inspection cover and seen fluid leaking from the front of the cylinder that would be the front of the tractor. it looks like to me the fluid is coming from the metal plate that holds the spring to the control valve. If I rev the tractor up the arms will raise but if I stand on them it wont. After they are raised they don't bleed down. Is there an o ring on the control valve? Should it be running out around the spring ? It looks a little pitted, but I don't think it should Pou out like it does.
