ford 5600 seals ?????
tazzer
ok how hard is it going to be for me to change out the power steering seals on my 5600 ? the fuilds poor out from where the steering arm connects to the gear box.
still trying to find my manual but looks like there are a couple of seals and one felt type one.
OK I pulled the steering arm off and all I can see is two felt type seals , is this all that's there. I pulled the rod out that the arm attached too and see nothing alao.
There is 2 orings at outer edge of housing. Get one size bigger on id so shaft will move in it rather than turn in hsg and still leak. Iam guessing standard orings.
(quoted from post at 04:29:29 08/19/15) There is 2 orings at outer edge of housing. Get one size bigger on id so shaft will move in it rather than turn in hsg and still leak. Iam guessing standard orings.
Should there be some type of grove for them to be placed in ? I can not find any that looks like a oring would fit.
I found my manual and see the two orings your talking about but not sure how they would fit and keep from moving out of place.
Thanks for the help.
