Injector pump remove 9700
Seems like I get one thing fixed on this tractor something else goes wrong. Now I need to take off the injector pump. Can anyone tell me how to remove it, line up timing marks and what has to come off inside the timing cover. Thanks for any help. I have remover lots of pumps off IH & MASSEY tractors but not sure on this tractor.
After the cover plate is removed over the pump drive gear look for a line on the pump hub in one of the three gear slots, then turn engine as needed to line it with the aluminum front pump mark which is at about the 2 O clock position. The gear stays put but then remove the three bolts then hold the gear to the hub. Then with all lines and hardware off the pump can be removed.
