NAA cam follower advice
Abbby
New to me NAA. Have not even used it for real but 3 point does not go up all the way. Have it up on blocks so want to fix all right now. Pulled off hydraulic cover and cam follower pin pretty shot. Good news. So do I just replace and put back together or try and set adjustment at the same time? Do not want to mess anything up. IT manual requires some special tool.
So Cam follower pin was shot. Did not remove acorn nut and unscrew back pressure valve before removing? Not sure what that is. Got it back together and it works. Goes all the way up but does not go all the way down unless I switch to draft mode. Did my best to follow the adjustment process. Unsure if I want to go back in. If I understand exactly what I could do to fix I would go for it. Any ideas.
