Recently, I purchased a Ford 540A (1981?) industrial tractor. It is equipped with a front loader with a dedicated pump on front of engine. The loader works fine. The 3 point, however, does not work corretly. Sometimes, it will not lift, other times it does lift. To get the 3 point to lift, you move the lever to the rearward position and "play with" the draft control lever. When it does lift, the hitch raises slowly sometimes pausing. To me, it acts like not enough oil. Checking the oil in the transmission from the fill hole, if anything, it looks like the oil may be too full. The oil is dark colored. The tractor is equipped with an independant PTO. Any ideas where to start? Also, the Fast/Slow "knob" on right side of transmission housing is stuck in slow.
The 3 point on this tractor appear to be very similar to the 4600.
