macec3(TX)
I have a 5610 with manual transmission. Stuck clutch and the main gear selector is stuck in 4/8th gear. The hi/lo range selector works fine.
Jacked up rear end and rocked rear tires. Did not help.
Guess I need to remove the top of the transmission to see what is going on. Are there any precautions when removing the top. Are there any springs or small pieces that will fall out?
Do the shift levers have to be removed before taking the top off?
Any help will be greatly appreciated.
Thanks
Thanks
