sfcrusscanter
How do you test the generator? I keep having to jump start the tractor. Used a voltmeter on the battery and is is reading 5.85 volts. Close... I can't get any readings off either posts on the generator. I'm grounding to the frame, so I figure that I should be getting something. There is a plate on the generator saying that it was rebuilt, but it's been so long ago they only had the phone number without the area code. Lol, so I figure it's been at least 30 years ago. Thanks for the help. Russ, in Kansas.
Ps, it has a loader on it, so either the battery or the generator is going to be chore to change.
