Mr. T. Minnesota
Forum Members,
Attempted again to start the 800 today and failed. Ignition is the problem. There is current to the coil. Opened the distributor and checked the points and they seemed fine. Closed the points with ignition on and opened with a screwdriver. There was no spark. Changed the condenser and spark appeared. Tried to start and found no spark at the plugs. Would it be correct to change out the coil? That is the next step. Any other help is appreciated. To gain speed on turnover have been using a 12 volt on the starter only.
Mr. T. Minnesota
Mr. T. Minnesota
