Dean Olson
I recently bought a 2000 4cyl gas. I now have the owners and shop manuals. The trans was probably 4-5 quarts over filled. It was definitely hydraulic oil and not gear oil. The problem I'm having is the trans won't slow down enough to shift. I'm attributing that to the hydraulic oil as with the PTO engaged in stops enough to shift. Pilot bearing may be a sticking a little also.
From reading the archives I suspect that the hydraulics must be leaking into the trans. I've drained the trans to the correct level. I haven't run it enough to see if I'm losing hyd fluid and gaining in the trans. The hydraulic and rear end fluids where/are at correct levels when I bought it. Rear end appears to have hydraulic fluid in it also.
Here's the question. If I put gear oil in the trans can it end up in the hydraulics?
That's sure easier to try than splitting the tractor to replace pilot bearing.
