Mr. T. Minnesota
Forum Members,
Today I started helping a friend start an 800 Ford five speed.
It turns over but does not fire. Removed plugs and added gas to chambers and still no fire. Will test for the key working tomorrow. Question is, does the 800 have a resistor in the ignition system and if so where is it located? It has a 6 volt electrical system and a side mount distributor. I will be checking the points Thursday. Concerning the carb, is it the same as or close to an 8N carb? Any other hints on starting this 800 will be appreciated.
Mr. T. Minnesota
Mr. T. Minnesota
