cghbuilder86
Hi, some of you may remember a little bit ago I had questions on here about my tractor not charging. I finally got that issue all resolved. Re-conditioned the generator, new wiring harness, and new voltage regulator. Now for the next issue, it seems its started using more oil than it used to and it is constantly pumping white smoke out of the oil fill pipe. It seems something around half quart in about two hours of full throttle running. oil pressure is between 30-40 when opened up and heated up. it drops as the oil level goes down. I'm pretty sure it needs new plugs and wires. Have not taken the plugs out but they look bad on the outside, wires are lightly cracking and will shock you a little if you try and handle while running. Could the plugs and wires be causing oil consumption, smoking, and loss of power? I really can't tell anything about the points, and distributer, I dont know anything about those parts. It sounds like it runs pretty smooth when first started and doesn't sound as smooth after working a little while. It gets plenty of fuel, has new carborator, fuel sedimate bowl cleaned, new thermostat and radiator, new wiring, flushed and cleaned air filter canister. It seems a good engine tune up is the last thing to restore good power and how it runs. Is there anyway to evaluate the condition of the engine before doing a good tune up? I'm thinking about taking it to the local tractor place and getting a price for new plugs and wires, and have them inspect the points and coil and make sure its well tuned BUT, I don't want to spend the money on that just to find that it needs and engine rebuild, because I can't do that myself, and by the condition of the rest of the tractor cant justify spending that much on this tractor.
As far as needing more power goes, Im trying to pull a like new 5' bush hog. Set at a cutting height leaving grass 9-10" tall. cutter set 3/4 lower in the front than the back. The grass is mostly smooth grass and weeds, very little trees and brush to cut. And even though the grass is pretty thick and long, shouldn't a 9" cutting height be easy enough for this tractor?
