rear studs on a 800 RR
dmbinva
Is there an EZ way to replace the rear axle studs on a 850 ford? I have not found the right spot to get them out after driving them out of the axle, if there is a right spot
Boss
Aside from R & Ring the axle, the only way to install a new wheel lug bolt is to drill a hole in the backing plate in order to get the new bold in.
The Ford service manual includes directions and photo(s).
Dean
(quoted from post at 17:47:07 07/28/15) Aside from R & Ring the axle, the only way to install a new wheel lug bolt is to drill a hole in the backing plate in order to get the new bold in.
Dean
Thanks Guys, I had pondered that , It will make driving them in a breeze too
