gears
so putting my 3400 together and the spindle bushings have quite a bit of play in them, the lowers are huge at 49.3mm ID and they're only $20 each at the dealer. The uppers are apparently unique to the 3400 and are 38.25mm ID and run $50.52 each!
I've got a lathe, do I order something in bronze close in size from McMaster and make em to fit (go undersize on the ID to match the worn spindle) or do I need Steel?
Or, option 3, find out one of you guys has a spare set you want to get rid of.....
