63 4000 Power Steering Reservoir Clamp
TonyIN
Been a while since I've been on here or my tractor. Life you know. Sometimes tends to kick you where you don't liked to be kicked!
Anyways, had the lid to my eaton style pump with the reservoir blow off somewhere a while back. Have searched and its long gone. Have
found a lid for it and gasket but cannot find a clamp anywhere. No longer available.
Any ideas? Anyone used a clamp off of something else? Thinking I could make it work with an air cleaner clamp but...
Thanks for any leads or help.
Tony
if in a pinch, get a big hose clamp and bend up 2 U shaped pieces of metal to clamp the lid down, braze or tack the U shaped metal into the clamp then button up. Will run till you find the real thing.
