Adding Remotes to 4100
What is the function of the "detent" in the remote hydraulic control valve? I found used ones with and without detent and unsure which to order.
The one with the detent will stay engaged until the cylinder reaches the end of it's stroke then it will return to neutral due to the pressure increasing. The non detent returns to neutral as soon as you release the handle.
Mark
