Bleeding 801 power steering
polishdan
Just rebuilt power steering cylinders and have air throughout the system. Reservoir stays full & I have done some doughnuts in the pasture. My shop manual says bleed the system, but doesn't say how. Any recommendations?
Jack the front end up so both tires are off the ground then cycle the wheel for all the way one way back to the other a few times and that should bleed the system
That sounds like a great answer. This sucker has a Sherman over & under loader and is really some exercise without power.
I'll bet you that you do not have an over under but a combo. Never seen any thing but a combo on and 841 and also bet yours if you look will say as the model 8 4 1 S. Post back if you do not understand what I am saying
