trying to install a factory tail light on my 640 and my 871.
Both of them have the same issue:
The factory wiring is in place to the rear fender. however I am getting a voltage drop thru the wire.
ex: 871 is still 6 volt system. head lights work fine. all original wiring in place, check voltage at tail light- I have around 3-4v.
640- converted to 12 volts. original wiring all there, head lights work fine with 12v bulbs. check power at tail light- 3 volts.
I cannot follow the wire as it goes into the main harness, but I checked for continuity so know its good, tired hooking directly to battery and still nada.
Is there some kind of resistor in the tail light wiring? or is this just old wiring?
