Curt Cooke
Have stock 2 remote set up. Blew a hose, albeit a weakened one. It was the one connected to the "drop" port on the left side valve, #4 in the operators manual. Under what condition would there be any pressure at the drop port? With hose removed and the "fast dump" screw closed (in) and tractor running, valves in neutral position, no hydraulic at dump port. As I begin to back the dump screw out, hydraulic fluid begins to flow out of the dump port. That doesn't seem right to me. Also, is it even possible to operate, with pressure both ways, a two-way cylinder from that particular (the second or right side one) remote valve? Or is two way cylinder operation only available from the left side valve?
