I have a 601 that has been overhauled timing is set at 25 deg. before tdc
new carb. points, plugs,
getting good spark and fuel just rebuilt bout 2 months ago and it started an ran good, til I went up a hill and came back down it backfired at bottom and shut off. found the starter locked up and kicked sideways tore all teeth off starter and a few from flywheel, put new starter and flywheel ring, also headgasket was leaking because the part supplier gave the wrong one ordered right one and put everything back together
now tractor wont start acts like it wants to adjusted timing doesn't help either way I turn it
