ford 1910 Hydr
Loader will go up even pushing control forward. 3 Pt will not go up. Oil level OK. Can bleed oil off to get loader down. Loader will drop a 1/2" every few minutes when moving control. Can this be a pluged filter? airlock? Anyone got any ideas.
Hard to say exactly what's wrong without seeing it and understanding how the hydraulics are plumbed... but as a WAG I'd say something is buggered up in the loader control valve. MAbey a bad o-ring... My reasoning is that if the loader control receives oil ahead of the three point, and the loader wants to raise regardless of the lever position... it's probably taking all of the flow and sending it in that direction rather than the 3-point... I guess at this point I would disconnect the input and outlet lines from the loader valve and join them together and then see what happens with the 3-point.
Rod
Crazy but found the problem. The quick-disconnect under the tractor had got pulled just enough to stop flow. I was pulling on hoses and that one came apart. Thanks.
